X++: Working with System.Char in X++
Источник: http://blogs.msdn.com/b/x/archive/20...char-in-x.aspx
============== There are situations where it is useful to workl with characters in X++. As you know, X++ does not have the concept of characters in the defined in the language: Only strings are defined. However, it is not impossible to work with characters in X++, if you use the managed System.Char type. It will not win any prizes for elegance, but it works... Consider the following example: static void CharArray(Args _args) { System.Char[] chars; System.Char a, b; a = System.Char::Parse('a'); b = System.Char::Parse('b'); chars = new System.Char[2](); chars.SetValue(a, 0); chars.SetValue(b, 1); } Here an array containing to chars is created, and assigned the values {'a', 'b'}. Note the special trick used to create a character literal, using the System.Char::Parse method. Источник: http://blogs.msdn.com/b/x/archive/20...char-in-x.aspx
Опции просмотра | |
