Старый 06.06.2007, 10:07   #1
Dynamics AX: Yellow Lock in Dynamics AX 4.01
Источник: http://dynamics-ax.blogspot.com/2007...cs-ax-401.html
Alright not to get off the subject about the .Net BC and custom code in .Net using it. But I did come across something, that I guess I have never had to come across before. Anyway we have custom code on a form where we had to make use of the TabChanged() method. This was needed, best thing for the mod, so there you go.
Well when users wanted to move some fields around on the lines level, they could not. When you right clicked, and then clicked on setup, you see Yellow Locks on all the objects in the tree view, under the tab control where the TabChanged() method was modified. So in research of this issue, turns out that this is "Working as Designed" as the *Offical* word from Mcirosoft Dynamics Support.
This means that you can't have your cake and eat it too, for this type of situation. Basically you modify the TabChanged() ot TabChange() methods of a tab control, and you lock all fields in place as they exist in the AOT. So for everyone else who might run into this, just be aware this is the issue. The solution, do Not change those two methods, or just accept the users can't change the fields around and change them for the collective whole in the AOT.
Well check back as I continue my talks about the .Net BC and it's use for developing a custom ASP.Net application!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Старый 06.06.2007, 18:03   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
что за дурная привычка у этого Brandon George чужие комментарии удалять...
Старый 06.06.2007, 23:01   #3
Это о чем?
Старый 07.06.2007, 10:16   #4
gl00mie is offline
gl00mie
Это о чем?
Я ему написал в комментариях, что это известная еще в 3.0 "особенность", так он комментарий потер и у себя дописал «Let me add...»; причем это уже не в первый раз. Второй комментарий со ссылками на документацию он вроде тереть не стал.
Старый 07.06.2007, 10:18   #5
Дааа лаадно. Пусть себе стирает.
А ты, вместо того, чтобы оставлять коммент у него, оставь его здесь. Тогда его все прочитают, и никто уж точно не удалит
Старый 07.06.2007, 10:31   #6
gl00mie is offline
gl00mie
Здесь вопросы пользовательской настройки форм с перекрытыми методами tabChange находятся простым поиском, это обсуждалось уже минимум раза три.
Поля в строках закупки
Перемещение полей на форме
Еще раз про пользовательские настройки форм
Самое интересное, что и «search on the web», который ему-де не дал никаких результатов, тоже выдает ссылки на эти обсуждения, другое дело, что они на русском... но с буржуйскими цитатами документации Если бы было что-то новое, я, конечно, комментировал бы здесь...
За это сообщение автора поблагодарили: kashperuk (5).
Старый 07.06.2007, 15:31   #7
EVGL is offline
EVGL
4,445 / 3001 (0) ++++++++++
А давайте исключим гада из рассылки! Он все равно ничего дельного не пишет. Сплошное самолюбование и маркетинг американского образца: 'Katmai and you!'. 'e-Con and you!' Почти как 'Hot dog and you!' или 'Hot dogs: why do YOU care?'
Старый 07.06.2007, 15:38   #8
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
895 / 192 (8) ++++++
brandon said...
gl00mie,
[Your tone could be a little better, but the information is worth keeping. :-) Smile gl00mie, and turn to sm1ley!]
Это он ещё со злыднями не сталкивался)
Старый 07.06.2007, 15:47   #9
AndyD is offline
AndyD
2,560 / 2494 (89) +++++++++
Отпиши
Axapta v.3.0 sp5 kr2
Старый 07.06.2007, 16:02   #10
gl00mie is offline
gl00mie
По поводу его исключения я лично свое мнение высказывал в этой теме. Впрочем, чем дальше, тем полезного, мне субъективно кажется, меньше: из 96 заметок, что у меня сохранились с 11.04.2006, очень мало что можно было бы сохранить в "Избранном"
Ну... просто человек пишет больше для себя, чем для других.
Старый 07.06.2007, 16:04   #11
EVGL is offline
EVGL
Ok. Но flash-mobbing я уже начал.
Старый 07.06.2007, 16:05   #12
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
Отпиши
Отписал
Пока не удалил))
За это сообщение автора поблагодарили: EVGL (1).
Старый 07.06.2007, 16:10   #13
gl00mie is offline
gl00mie
Evgeny said...
Well... The Russian DAX community is getting angry and thinks of your excommunication. Keep smiling, Brandon!
На счет "экскоммуникации" - боюсь, он не поймет, чего лишился...
Старый 07.06.2007, 18:03   #14
EVGL is offline
EVGL
Сообщение от Recoilme Посмотреть сообщение
Отписал
Пока не удалил))
Уже удалил. У него как раз утро началось.
Старый 07.06.2007, 18:51   #15
Да пусть себе будет блог. Не думаю, что стоит его удалять из списка blog bot
Иногда ж все-таки пишет он путние вещи.
И, возможно, кому-то интересно даже то, что большинству не нравится.
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Dynamics AX: Why Dynamics AX beats SAP Blog bot DAX Blogs 0 10.01.2007 23:15
Часовой пояс GMT +3, время: 16:12.
