Старый 24.08.2007, 18:11   #1
Dynamics AX: MOSS 2007, EP and Dynamics AX
Источник: http://dynamics-ax.blogspot.com/2007...namics-ax.html
A fellow blogger over at: geekswithblogs.net/marcs found the following link to a recent white paper that Microsoft released talking about Microsoft Office SharePoint Services and the use of it with Dynamics AX and it's Enterprise Portal.
You can find the white paper here: Microsoft Whitepaper PDF format
What I like about this white paper is it approach to displaying the possibilities via possible real world examples. This goes through and talks about the following process examples:
- RFP Management
- Absense Request and Vacation SChedule Management
- Expense Reporting
This is all geared towards possible area's most businesses could use, especially the Absense Request. Mostly though for sure the Professional Services Vertical could really see such benefits from the supplied examples. What should be taken from this more is the fact that such possible workflows can be acheieved in such a way, and therefore should be considered in the design of solutions for clients information workers that purchase EP peice of Dynamics AX.
Thanks Marc S. for posting this White paper, good find, and well worth reading!
Check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Dynamics AX: Interview with Steen Andreasen 2007 Blog bot DAX Blogs 0 19.09.2007 21:42
Часовой пояс GMT +3, время: 14:35.
