Старый 17.11.2007, 05:45   #1
axaptapedia: Layer System
Источник: http://www.axaptapedia.com/Layer_System
Summary: New page: ==General== The layer system in Dynamics AX is an important feature for customization. Every element in the [[AOT]] has to be defined at a certain layer. There are 8 layers available in Dy...
==General==
The layer system in Dynamics AX is an important feature for customization. Every element in the [[AOT]] has to be defined at a certain layer. There are 8 layers available in Dynamics AX. For each layer exists an additional patch layer. Each layer can be seen as a overall partitioning of the system. The layers also define a range of IDs for elements created at this layer.
* SYS (System) 1-8000
* GLS (Global Solution) 8001-16000
* DIS (Distribution) 16001 - 18000
* LOS (Local Solution) 18001 - 20000
* BUS (Business Solutions) 20001 - 30000
* VAR (Value Added Reseller) 30001 - 40000
* CUS (Customer) 40001 - 50000
* USR (User) 50001 - 60000
You have to buy licence codes to get access to a certain layer. Typical customization layers are BUS and VAR. If you don't have a license code for a higher level, you are working per default on the user layer.
==Customization==
One of the greates features in Dynamics AX is that an element can be defined a multiple layers. The system takes always the element from the outermost layer. In contrast to normal development where you modify the original code, your overlay an element from a deeper level on a higher level. So it is still existent but not visible for the system. All you customizations are therefore on one layer, like VAR or BUS. That makes distribution of your solution as easy as possible. You just take the complete VAR layer and plug it into another application. This can be done by copying the corresponding file.
Как преобразовать System.Drawing.Bitmap в Bitmap/Image Аксапты? rkorchagin DAX: Программирование 7 31.03.2009 15:59
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
Issues concerning X++: Missing values: getting the System.Missing.Value value Blog bot DAX Blogs 0 16.01.2008 02:49
Часовой пояс GMT +3, время: 00:29.
