Старый 11.01.2008, 18:20   #1
axStart: What is my AOS, Client, Database doing (Process Explorer)
Источник: http://axstart.spaces.live.com/Blog/...C0A0!232.entry
Sometime you want to know what processes are running on the server. If I look at Task manager, I get a global Id?e. This task manager does not tell you what is running in your SVSHOST.EXE processes.
However there is a tool from MS that can help you out. The name of this tool is Process Explorer. Whit this tool you are more abele to see what is cooking and who is the owner of the software. Also you can see where this software is installed on you Server.
 download Process Explorer
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
axStart: What methods are called when a runbaseBatch process is executed? Blog bot DAX Blogs 0 11.03.2008 20:05
gatesasbait: Showing Database name of current AOS in AX 4.0x title bar Blog bot DAX Blogs 0 18.12.2007 19:50
Client AX4 не видит AOS soin DAX: Администрирование 19 24.11.2007 18:48
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Часовой пояс GMT +3, время: 04:52.
