При установке MS Dynamics AX 4.0 SP1 на ноутбуке с операционной системой Windows XP SP2 и MS SQL Server 2005 возникает следующая ошибка
![]() Log-file имеет следующий вид: Цитата:
=== Setup logging started: 13.10.2008 14:32:18 ===
Running file: C:\DOCUME~1\ANBE\LOCALS~1\Temp\AxSetup.exe Exe Version: 4.0.2214.0 Property: AosReportErrors set to: '0' (False) === Loading parameters from file === Property: RelatedFilesDir set to: 'C:\Дистрибутивы\Microsoft Dynamics AX 4.0 SP1 EE Release\' === Starting evaluation of existing installation state === Client.msi Installed: False ApplicationIntegrationServer.msi Installed: False NetBusinessConnector.msi Installed: False ComBusinessConnector.msi Installed: False === Checking parameters === === Starting UI phase === Property: LicenseTermsVersion set to: 'RU' Property: RunMode set to: 'SingleComputer' Property: InstallDatabase set to: '1' (Create) Property: InstallApplication set to: '1' (Copy) Setup has detected that you are installing Object server on an operating system that is not supported for Microsoft Dynamics AX. The supported operating system is Microsoft Windows Server 2003 with Service Pack 1. Property: InstallAos set to: '1' (True) Property: ClientAosServer set to: 'L94' Property: InstallClientUI set to: '1' (True) Property: InstallReportingServer set to: '0' (False) Property: InstallApplicationIntegrationServer set to: '0' (False) Property: InstallNetBusinessConnector set to: '1' (True) Property: InstallComBusinessConnector set to: '0' (False) Property: ClientLanguage set to: 'RU' Property: ClientHelpLanguages set to: 'EN-US;RU' Property: ApplicationRegion set to: 'EE' Property: AosInstanceName set to: 'AX40SP2' Property: AosInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Server' Property: AosReportErrors set to: '0' (False) The localized name for the NT Authority\Network Service account has been identified as NT AUTHORITY\NETWORK SERVICE. Property: AosInstanceName set to: 'AX40SP2' Property: AosInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Server' Property: AosReportErrors set to: '0' (False) Property: AosAccount set to: 'ru\anbe' Property: AosAccountPassword set to: '**********' Property: AosAccount set to: '' Property: AosAccountPassword set to: '**********' Property: DbServerType set to: '0' (SqlServer) Property: InstallDatabase set to: '0' (No) Property: DbSqlServer set to: 'L94' Connected to SQL Server: L94 Property: DbSqlDatabaseName set to: 'Ax40SP2' Property: ApplicationInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Application' Property: ClientInstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\40\Client' Property: AosStart set to: '1' (True) Property: AosStart set to: '0' (False) === Starting execution phase === === Setting up File server === Completed setup of File server. === Setting up Object server === Exception = System.NullReferenceException Message = В экземпляре объекта не задана ссылка на объект. FullText = System.NullReferenceException: В экземпляре объекта не задана ссылка на объект. в Microsoft.Dynamics.Setup.Misc.GetMachineDomain() в Microsoft.Dynamics.Setup.InstallSqlServer.GrantAosAccessToRemoteSqlServer() в Microsoft.Dynamics.Setup.MainForm.AosDbAccess() в Microsoft.Dynamics.Setup.MainForm.s250Timer_Tick() ==== Setup ended before completion. === |
