Старый 27.12.2008, 17:05   #1
Arijit Basu: Installing AX 2009 Reporting Extensions in MSSQL 2008 & WIN 2008
Источник: http://daxguy.blogspot.com/2008/12/i...xtensions.html
When we try to install AX 2009 SP1 Reporting Services on a PC running SQL 2008,we get an error saying that MSSQL 2005 SP2 is required. Well there is a solution to this issue which is as follows:
1. Locate the AX Reporting services dll from the extracted AX 2009 SP1 folder
[\\AX2009SP1\support\axsetupresources\microsoft.dynamics.setup.reportingservices.dll;File Version - 5.0.1000.52]
2. Extract the AX 2009 .iso to a shared folder
3. Copy the microsoft.dynamics.setup.reportingservices.dll into the folder:
\\DynamicsAX\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Setup
\\DynamicsAX\Msi\Components64\Program Files\Microsoft Dynamics AX\50\Setup
4. It will ask to replace the existing dll having File Version - 5.0.593.0. Say Yes and replace.
5. Then Install AX Reporting Services extensions. It works fine and the Reporting Extensions are installed nice.
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 06:49.
