Старый 13.02.2009, 14:05   #1
DeniZone: Invoking a method on a field in a form's datasource
Источник: http://denizone.blogspot.com/2009/02...-in-forms.html
I needed to call the modified method on a form's datasource's field to invoke the logic, which updated a couple of fields on the form. I had defaulted a value in the field on the table's initValue()-method but this - of course - means that the modified method is not in play.
Therefore I needed to call the method in code, for which I had two options, either calling the form controls method by setting AutoDeclaration to Yes and then calling modified or calling the datasource table's field's method which I chose.
e.g. ProdTable_ds.object(fieldnum(ProdTable, ItemId)).modified();
but where to place the code? After some time I found out that if I placed it on active() of the datasource the form showed the correct information.
/Happy hacking
DeniZone: How to tell if a form was opened with 'Go to main table' function Blog bot DAX Blogs 0 17.02.2009 19:05
axaptapedia: Validate field values on form Blog bot DAX Blogs 0 17.12.2008 12:05
axaptafreak: Getting new table fields into your form datasource Blog bot DAX Blogs 2 24.01.2008 22:51
Fred Shen: Access a method of formDataSource's field Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 22:09.
