axcoder: Mental framework
Источник: http://axcoder.blogspot.com/2009/07/...framework.html
============== Review of the book “Managing your supply chain using Microsoft dynamics ax 2009” After about 5 years of Ax development I’ve recognized that the model of Dynamics Ax functionality which I have in my brain is like photosynth – some areas, I worked with, covered by consistent pictures, but others are represented by random shots without high level overview. The majority of existing materials about Ax – like trainings, documentation, so on, use “hands on” approach – little introduction and very detailed description using screenshots, particular sequences of steps in term of buttons, etc. So I feel that there is a gap between short intros of documentation and very detailed contents (for example Russian docs contains of 2 volumes >1000 pages each). That’s why I was very interested when Dr. Scott Hamilton sent me kindly the book, which was written to give “mental framework for putting together the details” learned from various sources . So below are my impressions. The book contains 426 pages, and most of them are text description of Ax functionality: no screenshots, no concrete steps – just text, tables and business process flowcharts. Thus, the information density is quite high. The book consists of 15 chapters, each dedicated for some functional area. All chapters are in scope of SCM (you can see TOC at Amazon). Each chapter contain description of a functional area, case studies and executive summary. New features of Ax2009 (such as sites and purchase requisition) are reflected. What I like about the book
I’d buy the book if I haven’t one. I recommend it for everybody who want to have a consistent view of Ax SCM functionality. PS. there is also a new book by Dr. Hamilton - Managing Lean Manufacturing using Microsoft Dynamics AX 2009 Источник: http://axcoder.blogspot.com/2009/07/...framework.html
Автор меня попросил спросить у комьюнити, насколько нужен перевод такой книжки на русский язык
Но с подходом абсолютно согласен. Цитата:
но я не понял - сообщение про старую книгу? тогда она уже переведена http://www.ozon.ru/context/detail/id/2430490/ но, насколько я помню, там ничего по функциональности ax2009 не было. Цитата:
Сообщение от Blog bot
![]() PS. there is also a new book by Dr. Hamilton - Managing Lean Manufacturing using Microsoft Dynamics AX 2009
also вот вам ссылка на то, о чем мы говорили? или also есть и другая книга, о которой здесь не говорили, но она тоже по теме? Цитата:
Я не в восторге от переводов его книг, считаю, что там очень много воды. И очень много несовпадений и с Аксаптой, и с Навижином. Возможно, это эффект перевода. Но в них действительно содержатся ответы на вопросы "почему так сделали". В этом его книги уникальны. Поэтому перевод книги Гамильтона должен быть, на мой взгляд. |
Чел - это я - считает, что то, что описано, описано на уровне скриншотов и нажатий на кнопки, а не концепции.
возможно, мой английский недостаточно хорош. но я не понял - сообщение про старую книгу? тогда она уже переведена http://www.ozon.ru/context/detail/id/2430490/ но, насколько я помню, там ничего по функциональности ax2009 не было. Цитата:
А как понимать это "also"?
перевод на русский книг Гамильтона - нужен. Я не в восторге от переводов его книг, считаю, что там очень много воды. И очень много несовпадений и с Аксаптой, и с Навижином. Возможно, это эффект перевода. Но в них действительно содержатся ответы на вопросы "почему так сделали". В этом его книги уникальны. Поэтому перевод книги Гамильтона должен быть, на мой взгляд. |
За это сообщение автора поблагодарили: Kabardian (3). |
я думал, что ты просто опубликовал сообщение от хамильтона.
извини, круто ошибся. реально, извини. Цитата:
Только переводить ее должны люди, которые знают Аксапту, чтобы не получилось "как раньше". Цитата:
![]() новая книжка по Lean Manufacturing - это та же самая "новая книжка, в которой есть про Ax2009"? Или это какая-то другая новая книжка? |
#6 |
Ничего - все нормально
Это две разные книжки: Цитата:
![]() Review of the book “Managing your supply chainu sing Microsoft dynamics ax 2009”
... PS. there is also a new book by Dr. Hamilton - Managing Lean Manufacturing using Microsoft Dynamics AX 2009 |
За это сообщение автора поблагодарили: mazzy (2). |
#7 |
Кстати, что можно почитать не привязанное к конкретно аксапте. В смфсле про бизнес проуессы обычно поисходящие на западе при покупке продаже производстве и т.д.
#8 |
Когда то искал Управление цепочками поставок под 3.0 не нашёл, даже в электронке.
Всё раскупили. Тираж походу маленький был. Если будет перевод обязательно почитаю.
Энергия молодых и неравнодушных способна изменить мир к лучшему. |
За это сообщение автора поблагодарили: belugin (1). |
#9 |
За это сообщение автора поблагодарили: belugin (3). |
#10 |
Талантливый разгвоздяй
Книги Скотта Гамильтона по SCM
Оказывается, Скотт Гамильтон написал книги по SCM почти по всем версиям AX:
Managing Your Supply Chain Using Microsoft Navision Managing Your Supply Chain Using Microsoft Axapta Managing Your Supply Chain Using Microsoft Dynamics AX Managing Your Supply Chain Using Microsoft Dynamics AX 2009 |
#11 |
Сообщение от Kabardian
![]() Оказывается, Скотт Гамильтон написал книги по SCM почти по всем версиям AX:
Managing Your Supply Chain Using Microsoft Navision Managing Your Supply Chain Using Microsoft Axapta Managing Your Supply Chain Using Microsoft Dynamics AX Managing Your Supply Chain Using Microsoft Dynamics AX 2009 ![]() Управление цепочками поставок с Microsoft Navision Управление цепочками поставок с Microsoft Axapta |
#12 |
выдержка из книги Scott Hamilton, Managing Lean Manufacturing Using Microsoft Dynamics AX 2009 (http://msdynamicsworld.com/story/bil...ng-using-micro)
#13 |
Да, я тоже считаю, что это очень хорошая книга. Правда я так пока до нее не добрался, поэтому это только мои предположения.
Я все еще пока "мучаю" APICS. Интересно, но уж слишком много разных бизнес-процессов, и когда ты с ними напрямую в данный момент не работаешь, через месяц уже тяжело что-то вспомнить. Но, наверное, общие понятия она таки дает. А Гамильтон рулит |
#14 |
И какая конкрентно? |
#15 |
За это сообщение автора поблагодарили: apanko (2). |
Теги |
ax2009, download, книга, производство, управление запасами, управление проектами, управление цепочками поставок, загрузка |
