Старый 22.10.2009, 01:09   #1
axaptapedia: Sandcastle
Источник: http://www.axaptapedia.com/Sandcastle
Summary: /* Modifying the generated reflection file (reflection.org) */
<div>== Introduction ==
[http://sandcastle.codeplex.com Sandcastle] documentation compilers enable managed class library developers throughout the world to easily create accurate, informative documentation with a common look and feel. With Dynamics AX, one can create [http://msdn.microsoft.com/en-us/library/cc593549.aspx XML documentation files] that can be compiled with [http://sandcastle.codeplex.com Sandcastle] to create [http://en.wikipedia.org/wiki/Microso...iled_HTML_Help CHM help] files.
An [[media:ShellExecute.chm.zip|example]] of Dynamics AX XML documentation compiled with Sandcastle:
[[Image:ShellExecute.png]]
== Required Software ==
Microsoft .NET Framework Version 2.0, available [http://msdn.microsoft.com/netframewo...s/default.aspx here]
HTML Help Workshop available [http://msdn.microsoft.com/library/de...pDownloads.asp here]
Sandcastle available [http://sandcastle.codeplex.com/Relea...tReleases.aspx here] or [http://www.microsoft.com/downloads/d...5-696e3a4873b2 here]
== Steps ==
# Creating the XML documentation files
# Modifying the generated reflection file (reflection.org)
# Optional additions
# Compiling Sandcastle
=== Creating the XML documentation files ===
Follow the steps described in the [http://msdn.microsoft.com/en-us/library/cc654944.aspx Dynamics AX 2009 SDK] to generate the XML documentation files. Be sure to store both the documentation and reflection file in the same folder and name them as follows:
comments.xml (documentation file)
reflection.org (reflection file)
=== Modifying the generated reflection file (reflection.org) ===
In order for Sandcastle to create the table of contents and generate the html files, the following changes need to be made to the reflection file:
Replace the first occurance of ''
axaptapedia: Sandcastle Blog bot DAX Blogs 0 17.10.2009 13:05
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 11:39.
