Старый 14.11.2009, 22:05   #1
Arijit Basu: AX Application Launcher v2
Источник: http://daxguy.blogspot.com/2009/11/a...uncher-v2.html
Sometimes back I created an application "AX Configuration Launcher" which helped distribute AX Configurations enabling users to open multiple configurations easily. I made some improvements to the earlier application as:
1. New User Interface
2. Ability to sync from a centralized network share
3. Ability to configure the application (Advanced users, config stored in a XML file)
The screenshot is as follows:-
The video to install and use is displayed below:
The installation files & video are shared in the link below.
I tested it out on my local machine as well as at my client. It working fine. The network shared folder must have read access to all users using this tool. In case you use this application, do give me the feedback.
I will publish the source code in Codeplex (Im working on this now to get a license in Codeplex)
Arijit Basu: AX Application Launcher Blog bot DAX Blogs 0 21.02.2009 19:06
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Dynamics AX: Microsoft Dynamics AX (DAX): Known Issues when upgrading to Microsoft Dynamics™ AX 4.0 - Arijit Basu | AX MVP Blog bot DAX Blogs 0 31.05.2007 03:30
Часовой пояс GMT +3, время: 10:00.
