Старый 19.08.2010, 10:05   #1
sumitax: Trobleshooting Project/AxBaseUserControl.ascx does not exist error
Источник: http://sumitax.wordpress.com/2010/08...t-exist-error/
Issue:
While working on EPSalesTableInfo  user control in my VS2008 Project , I faced an issue during compilation on line
partial class EPSalesTableInfo : AxBaseUserControl
 The best overloaded method match for ‘Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts.AxBaseWebPart.GetWebpart(System.Web.UI.Control)’ has some invalid arguments
 Resolution :
The fix to above error is to include “AxBaseUserControl”user control in your VS 2008 Project using the “Add user control from AOT ” option.
Error 1075: The dependency service does not exist or has been marked for deletion Blog bot DAX Blogs 1 24.10.2011 14:26
daxdilip: Troubleshooting AX 2009 Enterprise Portal Error The type or namespace name "Portal" does not exist in namespace 'Microsoft.Dynamics' Blog bot DAX Blogs 0 12.08.2010 11:05
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
emeadaxsupport: Project module Excel pivot table fails with error 0x80070057 E_INVALIDARG Blog bot DAX Blogs 0 10.05.2010 21:05
Часовой пояс GMT +3, время: 13:38.
