Старый 04.09.2010, 05:11   #1
Solutions Monkey: Debugging X++ code on EP pages (AX 2009)
Источник: http://blogs.msdn.com/b/solutions/ar...s-ax-2009.aspx
As per Flemming Gregersen's request posting this info
Here is the article to on How to: Debug X++ Code on EP Pages
Make sure you login to the machine in console mode. Also if UAC is enabled, you have to run AX Client with admin privileges (right click and ‘Run as Administrator’) to get the debugger to work. Also note that KB2251040 is required only for WCF debugging, KB962952 is required for EP debugging.
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Часовой пояс GMT +3, время: 12:56.
