Старый 06.12.2012, 10:48   #1
polygris is offline
polygris
AxAssist
272 / 67 (3) ++++
AX 2012 R2 инсталляция
AX 2012 R2
Во время синхронизации базы вываливается такая ошибка
Microsoft.Dynamics.Ax.Xpp.InfoException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.InfoException' was thrown.
   at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue)
   at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.callReturn(Int32 rc, interpret* ip)
   at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.CallStatic(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs, Type[] varargsTypes)
   at Microsoft.Dynamics.Ax.Xpp.XppObjectBase.StaticCall(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs)
   at Dynamics.Ax.Application.Debug.assert(Boolean expression)
   at Dynamics.Ax.Application.DimensionEnabledType.constructForSystemDefinedByTableId(Int32 _viewId, String _viewLabel, Boolean ) in DimensionEnabledType.constructForSystemDefinedByTableId.xpp:line 200
   at Dynamics.Ax.Application.DimensionEnabledType.constructForSystemDefinedByTableId(Int32 _viewId)
   at Dynamics.Ax.Application.DimensionAttribute.getAttributeByHierarchyType(DimensionHierarchyType _hierarchyType) in DimensionAttribute.getAttributeByHierarchyType.xpp:line 116
   at Dynamics.Ax.Application.DimensionHierarchy.getHierarchyIdByHierarchyType(DimensionHierarchyType _hierarchyType) in DimensionHierarchy.getHierarchyIdByHierarchyType.xpp:line 88
   at Dynamics.Ax.Application.DimensionHierarchy.getSystemGeneratedHierarchyIds() in DimensionHierarchy.getSystemGeneratedHierarchyIds.xpp:line 21
   at Dynamics.Ax.Application.DimensionMetadataSetup.Loaddata() in DimensionMetadataSetup.loadData.xpp:line 9
   at Dynamics.Ax.Application.SysSetupInstaller.Writealldata() in SysSetupInstaller.writeAllData.xpp:line 19
   at Dynamics.Ax.Application.SysSetupInstaller.Run() in SysSetupInstaller.run.xpp:line 7
   at Dynamics.Ax.Application.SysSetupInstaller.loadPartitionData(Object[] _c) in SysSetupInstaller.loadPartitionData.xpp:line 3
   at SysSetupInstaller::loadPartitionData(Object[] )
   at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
   at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog)
Сталкивался кто нибудь с такой ошибкой? Полная компиляция приложения и FULL CIL Compilation сделаны.
Старый 06.12.2012, 15:30   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Судя по всему срабатывает вот этот assert в методе constructForSystemDefinedByTableId
 // Verify the type will be able to be created completely
    if ((sysDictTable.name() == '') || (tableId2name(backingEntityTableId) == '') || (fieldId2Name(backingEntityTableId, dictView.fieldId(keyField)) == '') || (fieldId2Name(backingEntityTableId, dictView.fieldId(valueField)) == '') || (dictView.label() == ''))
        // The fields are always required in order for the dimensions subsystem to successfully link to the correct table and columns. This is a coding error so assert false
        Debug::assert(false);
        return null;
Поробуйте отключить отладку (в параметрах пользователя Debug mode: No)
Попробуйте отключить IL
Попробуйте позвать программера и найти причину, по которой сабатыввет ассерт.
Приложение кастомизированное?
Старый 06.12.2012, 18:00   #3
polygris is offline
polygris
AxAssist
272 / 67 (3) ++++
Да я сам и программер есть :-)
Решение не кастомизированое - ставлю с нуля AX 2012 R2
Я уже немного другим способом решил проблему
сдесь закоментил часть российской функциональности. Отрубил российскую функциональность.
Засинхронизировал все. Включил российскую функциональность. Разкоментил. Снова засинхронизировал.
Старый 10.12.2012, 17:39   #4
cyrus is offline
cyrus
OntargIT
22 / 19 (1) ++
Синхронизация при установке прерывается такой ошибкой в том случае, если у view DimAttribute* (см в методе getAttributeByHierarchyType) для связанных конфигурационных ключей не активированы лицензионные ключи. Например, русские ОСы не активируются, если загружаем лицензию 2012 RTM, а не R2.
Старый 29.04.2013, 15:38   #5
f18 is offline
f18
Аватар для f18
Дети Юза
188 / 101 (4) +++++
Ax 2012 R2
Боролся, боролся с такой ошибкой (2е суток), почел эти сообщения, попробовал - ничего не вышло. А вышло след образом
1. Инсталлируем
2. Запускаем аксу
3. Компилируем
4. Компилируем CIL
5. Лицензии не вводим а щелкаем на галке - отметить как выполненное.
6,7,8 ...
n+1. Синхронизируем
После запуска Аксы, вводим лицензии и синхронизируется еще раз. При таком подходе подходят и экзотические лицензии от RTM (а другой у меня и нет).
Может быть кому-то будет полезным.
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Часовой пояс GMT +3, время: 11:18.
