Старый 03.05.2011, 21:11   #1
sumitsaxfactor: Generating Next Number Sequence in SQL
Источник: http://sumitsaxfactor.wordpress.com/...quence-in-sql/
In my last article, I explained how to Generate RecIds in SQL Server.
In this article, I will provide a SQL Job to automatically generate next number sequence if a field is getting populated using Number sequences. I created this job recently for InventTransId.
So here is the job that will help you generate next number sequence in SQL. I have tried to put in as many comments as possible:
DECLARE @FORMAT AS NVARCHAR(20), @TMPFORMAT1 AS NVARCHAR(20), @TMPFORMAT2 AS NVARCHAR(20), @NEXTREC AS INT
DECLARE @FINALID AS NVARCHAR(20)
–FETCH THE NUMBERSEQUENCE FORMAT AND VALUES FOR INVENTTRANSID (Lot ID)
–NOTE THAT 582 is the Extended Type Id for InventTransId
SELECT
@FORMAT =FORMAT, @NEXTREC =  NEXTREC FROM NUMBERSEQUENCETABLE
WITH
(UPDLOCKHOLDLOCK)
JOIN NUMBERSEQUENCEREFERENCE ON NUMBERSEQUENCEREFERENCE.NUMBERSEQUENCE NUMBERSEQUENCETABLE.NUMBERSEQUENCE
AND NUMBERSEQUENCEREFERENCE.DATATYPEID 582 AND NUMBERSEQUENCETABLE.DATAAREAID ‘CEU’
–GET THE
# CHARACTERS IN ONE VARIABLE AND FIXED CHARACTERS (IF ANY) IN ANOTHER
–EX######_068 WILL BE BROKEN INTO "######" AND "_068"
SET @TMPFORMAT1=SUBSTRING(@FORMAT1LEN(@FORMAT)-CHARINDEX(#’,REVERSE(@FORMAT))+1)
SET @TMPFORMAT2=SUBSTRING(@FORMATLEN(@TMPFORMAT1)+1LEN(@FORMAT)-LEN(@TMPFORMAT1))
–NOW REPLACE # WITH REQUIRED ZEROS AND THE NEXT RECORD NUMBER THEN APPEND THE FIXED CHARACTERS AND DISPLAY OUTPUT
SET @FINALID = (REPLICATE(’0′LEN(@TMPFORMAT1)-LEN(CAST(@NEXTREC AS NVARCHAR))) + CAST(@NEXTREC AS NVARCHAR)) + @TMPFORMAT2
SELECT
@FINALID as INVENTTRANSID
Последний раз редактировалось Poleax; 03.05.2011 в 22:17.
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Issues concerning X++: SQL improvements in the next version of Dynamics AX Blog bot DAX Blogs 4 25.09.2007 19:40
Number sequence problems - Ax3 sp3 ginmur DAX in English 2 11.06.2007 19:48
Arijit Basu: New Number Sequence for new AX Module Blog bot DAX Blogs 1 16.04.2007 10:39
Часовой пояс GMT +3, время: 12:21.
