Старый 24.10.2011, 23:11   #1
Kashperuk Ivan: Tutorial: AX2012 - A new way of accessing the QueryBuildDataSource for a particular FormDataSource
Источник: http://kashperuk.blogspot.com/2011/1...accessing.html
When playing with some X++ code, I found an interesting addition that happened in AX 2012 related to form development.
There are 2 new methods that were added to the FormDataSource class, which allow you to very easily and error-free access the underlying QueryBuildDataSource, whether that is for the initial form query or for the queryRun that also contains user filters and sorting.
So, for example, instead of writing:
this.query().dataSourceTable(tableNum(InventTableModule), 2);
this.queryRun().query().dataSourceName(identifierStr(Purch));
you can use the 2 new methods:
this.queryBuildDataSource();
this.queryRunQueryBuildDataSource();
It might seem as a very minor improvement, but in reality it greatly simplifies maintenance of code on forms, when new datasources are added or existing ones removed/renamed.
That's all for today.
Kashperuk Ivan: Tutorial: refresh, reread, research, executeQuery - which one to use? Blog bot DAX Blogs 20 04.04.2017 13:23
Kashperuk Ivan: Tutorial: Table Relation properties in AX 2012 Blog bot DAX Blogs 3 09.05.2011 00:06
Kashperuk Ivan: Tutorial: Undocumented behavior of kernel functions min()/max() Blog bot DAX Blogs 0 24.09.2010 01:06
Kashperuk Ivan: Casing and text search/comparison tutorial Blog bot DAX Blogs 6 25.02.2010 15:41
Kashperuk Ivan: tutorial_Form_Dynalink (a small tutorial on dynalinks) Blog bot DAX Blogs 0 22.08.2007 17:00
Часовой пояс GMT +3, время: 12:46.
