Старый 10.02.2012, 12:11   #1
palleagermark: Inserting code snippets in the AX 2012 X++ editor
Источник: http://palleagermark.blogspot.com/20...x-2012-x0.html
In the AX 2012 X++ you can quickly insert fragments of code to avoid tedious typing, such as typing for a loop.
To insert a snippet, you must enter the snippets alias (which is usually the first symbol of the code), and press tab. For example, typing switch followed by tab, gives you this snippet:
switch ()
case :
break;
case :
break;
I don't have a clear picture of all the available aliases, but these work:
  • switch
  • for
  • do
  • while
  • try
In the regular Visual Studio editor you can add your own code snippets. I haven't figured out yet, if this is also possible for the X++ editor.
palleagermark: "Find as you type" in the AX 2012 X++ editor Blog bot DAX Blogs 0 02.02.2012 15:11
palleagermark: Color code forms in AX 2012, depending on environment/company Blog bot DAX Blogs 0 12.12.2011 15:11
Часовой пояс GMT +3, время: 04:51.
