Старый 26.07.2012, 17:11   #1
sashanazarov: Parm-methods generator script
Источник: http://sashanazarov.blogspot.com/201...or-script.html
It may be boring to manualy create parm-methods for each an every class member variable, although there is an editor script for that. By the way, there is a bug-o-feature in AX 2012 editor, which does not allow you to select anything but an EDT for the variable type.
This is a script that auto-generates parm-methods for a class, based on its class declaration:
<span style="font-size: x-small;">static void createParmMethod(Args _args)
#AOT
ClassName className = classStr(MyClass); //
sumitsaxfactor: Using Methods Inside Query Range Blog bot DAX Blogs 0 05.05.2011 20:12
kamalblogs: Data methods in Ax Reports and SSRS Reports Blog bot DAX Blogs 0 22.12.2010 12:11
axaptapedia: Call-back methods Blog bot DAX Blogs 0 20.05.2010 00:05
axaptapedia: Accessor Methods Generator Blog bot DAX Blogs 0 05.03.2010 17:05
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
Часовой пояс GMT +3, время: 01:24.
