Старый 25.10.2012, 00:11   #1
kamalblogs: ALM (Deployment) with Dynamics Ax 2012 R2
Источник: http://kamalblogs.wordpress.com/2012...cs-ax-2012-r2/
- Metadata db and the datadb can now be separate
- Single user Topology for development: Microsoft recomments the Single user topology when using sourcecontrol and to manage multiparty development
- Shared application topology is not recommened for the following reasons
- To debug a Pcode the visual studio needs to be used. During the attach process the AOS is paused for all user
- Server restarts for a single user stops the entire application
- Visual Studio Projects – Apart from the Synchornize to the AOT, we must right scripts to run MSbuild for these projects. This
ensures a proper VS project import
Deploying to the Production
- Element id’s as we all know is generated during the import of models, so it is recommended not to import models in to Production
system to avoid id conflicts
- Maintain a seperate staging setup where the metadatastore of the production and staging are maintained commonly. Import models to
the staging and then move the metadata
- Model store import is quicker, will bring the down time and speed up import.
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 05:25.
