Старый 07.12.2012, 23:12   #1
emeadaxsupport: Dynamics AX 2012 EP: Problem with installing Enterprise Portal " User cannot be found."
Источник: http://blogs.msdn.com/b/axsupport/ar...ound-quot.aspx
Couple of times we saw the issue while running axsetup.exe to install Enterprise Portal that is failing with error:
Entering function CurrentUserAlias
Leaving function CurrentUserAlias
Creating new Enterprise Portal Site with following the parameters:\n URL: http://daxtstep.exnet.sas.com/sites/DynamicsAx\n Title: EP Site\n LCID: 1033\n OwnerLogin: CARYNT\spdax
Administration Web Service URL: http://daxextst01:10000/_layouts/ep/WSSAdmin.asmx
An error occured while Setup was creating a new site.
Exception of type 'Microsoft.SharePoint.SoapServer.SoapServerException' was thrown.
User cannot be found.0x80131600
System.Web.Services.Protocols.SoapException
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Microsoft.Dynamics.Framework.Deployment.Portal.WSSAdmin.CreateSite(String Url, String Title, String Description, Int32 Lcid, String WebTemplate, String OwnerLogin, String OwnerName, String OwnerEmail, String PortalUrl, String PortalName)
at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.CreateDefaultEPSite(String virtualServerUrl)
To overcome this issue we need to:
Make sure that Central Administration service is running as internal user domain account. To change Central Administration account you can use following procedure (also applicable for SharePoint 2010)
http://technet.microsoft.com/en-us/l...ffice.12).aspx
emeadaxsupport: Microsoft Dynamics AX 2009 Enterprise Portal installation error Blog bot DAX Blogs 0 22.09.2011 20:11
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Часовой пояс GMT +3, время: 10:26.
