axStart: Ax 2012 (R2) Labels
Источник: http://www.axstart.com/ax-2012-r2-la...2012-r2-labels
============== I see a lot of people having trouble with their labels in Dynamics AX. I will explain a little bit on how it works on the backend. The first thing you should know is that the label files are stored in the model. This is handy, but there is a catch. Restarting the AOS service can (or will?) override the *.ald (label) files. Sometimes you want to force this override of the label file. This can be done by deleting the *.ald files in the bin folder of the AOS service, when the AOS service is down. A restart of the service will regenerate the files. The next step is: How do I get my labels in the model? How to make a net translation of your labels. Example I bought a solution with only EN-US labels. Follow the steps below:
Final remark. The developer documentation label on the table properties must have description {locked} Источник: http://www.axstart.com/ax-2012-r2-la...2012-r2-labels
