Старый 21.07.2013, 21:11   #1
bojensen: Stack trace: Invalid attempt to call WinAPI::findFirstFile running in CIL on the client.
Источник: http://blogs.bojensen.eu/?p=4731
This error you will normally encounter when running a batch job. The issue is that batch processing doesn’t suppport WINAPI::findFirstFile method. Actually I was trying to find a file in the folder and moving to some other folder, you can use this alternative: public void run(){    System.IO.DirectoryInfo di;    System.Type arrayType;    System.Array array;    System.IO.FileInfo fi;    FilePath [...]
emeadaxsupport: Finding the X++ call stack that caused a crash Blog bot DAX Blogs 2 14.01.2020 13:20
emeadaxsupport: Running AX 2009 Client raises error: "An invalid directory structure for Microsoft Dynamics AX was detected" Blog bot DAX Blogs 0 01.04.2011 06:13
fed: Tracing in Dynamics AX 4 and 2009 Blog bot DAX Blogs 0 10.03.2010 20:05
msdynamicsax: How to get the current call stack in X++ Blog bot DAX Blogs 0 16.01.2009 18:05
daxmy: Financial Statement - Stack trace error Blog bot DAX Blogs 0 31.10.2007 17:40
Часовой пояс GMT +3, время: 04:42.
