Старый 23.10.2013, 02:11   #1
emeadaxsupport: AX 2012 R2 for Retail - Configuring the EFT Service in the Retail Hardware Profile with Dynamics Online Payment Services
Источник: http://blogs.msdn.com/b/axsupport/ar...-services.aspx
The steps below will walk you through connecting a payment service that is already set up in Dynamics Online to your EFT Service in the Retail Hardware Profile. These steps would need to be followed for each new hardware profile that is configured for each store that has a different payment service. If you have different hardware profiles for the same store and want to use the same payment service on each profile, you would still need to perform these steps. The Microsoft account would be the same, but the system user would still need to be created in Dynamics Online as the public key would be different for each hardware profile. With this in mind, you can also use these same steps to configure the same payment service in a Test environment and a production environment.
For information on configuring POS into a Test Mode, go to: http://blogs.msdn.com/b/axsupport/ar...t-service.aspx
1. Go to www.dynamicsonline.com
2. Select For Customers.
3. Log in with a Microsoft Account (also known as Windows Live ID).
NOTE: If this auto logs you in with an account that is saved in the browser that is not valid for Dynamics Online, go to www.live.com and sign out first.
4. Select Service List in the left navigation pane.
5. Find the payment service that you would like to link to your AX company.
6. Copy the Service ID from ID field.
7. Leave this window open and switch to AX.
8. Go to: Retail >> Setup >> POS >> Profiles >> Hardware profiles
9. Either select an existing profile to modify it, or click New to create a new hardware profile with a new name.
10. Expand the EFT service fast tab
11. Select Payment Connector as the EFT Service (The Dynamics Online dropdown option is used for internal testing only, this option is removed in CU6)
12. Select the profile version of the POS
13. Enter in the Microsoft account and Microsoft account password.
NOTE: This is also known as your Windows Live ID. The user entered here is what is used to access Dynamics Online and the payment service. They must be set up with access to that payment service in order for the login to authenticate. Setting up a "User" account can be done in the Dynamics Online partner or customer portal.
For steps on setting up user roles, click the following link: http://blogs.msdn.com/b/axsupport/ar...ser-roles.aspx
14. The Environment field is already populated as PROD and this should be left as is.
15. Highlight and copy the entire Public key. As a test, paste the contents into a text document to ensure it copied the contents properly. This is a fairly large key and at times this has a tendency to copy the fields in the form instead of the key. If this happens, simply close the payment services window and reopen it to try the copy again.
16. Switch back to the Dynamics Online customer portal.
17. Click User management in the navigation pane.
18. Click New "System User"
NOTE: This is different than the user in Step 13. This system user account hosts the Public Key that helps connect the ERP to Dynamics Online.
19. (Optional) Change First and Last name. I recommend doing this to know which entity this system user is for if you have more than one payment service set up.
20. Paste in the Public Key into the Public Key field. (the contents of this field will not be visible after saving the system user)
21. Click Save.
22. Select the System User we just created by placing a checkmark next to it.
23. Click Edit.
24. Add the specific system user role for that payment service or all roles to the Selected Roles by clicking on the >> sign.
25. Click Save.
26. Switch back to the AX
27. Go to: Retail >> Periodic >> Data distribution >> Distribution scheduler
28. Select the A-1090 or N-1090 job to update the POS with the hardware profile update.
29. Click Run directly
30. Start POS or restart POS (just the POS application) if POS was already open.
31. Process a test transaction with your credit card tender process.
ADDITIONAL NOTES:
1. Normally any authentication issues deal with the user or system user account not having access to the payment service.
2. Ensure that https://paymentservice.dynamics.com/...ntservice.asmx is added to the firewall for the system processing the payment
3. Error 50000 - This refers to a credit card misconfiguration in AX with the payment method, card type, or card number.
emeadaxsupport: AX 2012 R2 - Connecting a Dynamics Online payment service to AX accounts receivable Blog bot DAX Blogs 0 04.10.2013 19:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
Часовой пояс GMT +3, время: 05:02.
