Старый 24.01.2015, 03:17   #1
Breakpoint; in CIL code
Источник: http://alexvoy.blogspot.com/2015/01/...-cil-code.html
I needed to debug batch processing in BatchRun.ServerGetTask() method.
It was a wrong idea to add breakpoint; instruction into a managed code. Of course, after stopping my AOS did not start anymore because of the error:
Just-In-Time debugging this exception failed with the following error: The operation attempted is not supported
The easiest way to recover this problem is to delete the forementioned instruction and recompile CIL, but I have not access to AOT X++ editor anymore.
Alternatevily, as described in How-To-Debug-Managed-Code-In-AX2012, I did catch this breakpoint in Visual Studio during the short period between Starting and Stopped statutes of AOS service.
Launch Visual Studio as administrator.
Open the class method in question directly frpm xppCIL\Source folder.
Start the AOS service.
Switch back to Visual Studio and attach to the process. It appeared in a few seconds.
Then it stopped at the problematic breakpoint.
Pressing F5 each time it stopped there (actually every minute, as it supposed to be for batch processing), I changed my code back and run full CIL.
Please, do not place breakpoint; in managed code like I did.
Full MSDN article about debugging in AX 2012.
Microsoft Dynamics CRM Team Blog: Check your JavaScript code to prepare for your upgrade Blog bot Dynamics CRM: Blogs 0 24.08.2013 04:19
X++ to CIL Blog bot DAX Blogs 0 01.04.2013 14:11
X++: .NET Interop to X++ When X++ Runs as CIL Blog bot DAX Blogs 0 21.09.2011 05:12
kamalblogs: Adding a breakpoint through code in Dynamics Ax Blog bot DAX Blogs 18 18.08.2010 11:28
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 03:07.
