Старый 25.08.2015, 11:11   #1
dynamicscpm: Management Reporter CU13 Hotfix Now Available
Источник: http://blogs.msdn.com/b/dynamics_fin...available.aspx
An issue was discovered with Management Reporter CU13 related to how reporting trees displayed in the web viewer. The scrollbar in the reporting tree window doesn't display when the reporting tree button selected after CU13 is applied. With this hotfix, the scroll will now display.
Issue ID
Title
3660417
Web Viewer missing scroll bar for tree units with CU13
You can download the hotfix from CustomerSource.
Version history
Management Reporter CU13 - 2.12.13001.13
Management Reporter CU13 Hotfix - 2.12.13001.16
dynamicscpm: Management Reporter 2012 CU11 Hotfix 3 Now Available Blog bot DAX Blogs 0 17.02.2015 03:21
dynamicscpm: Management Reporter 2012 CU11 - Hotfix 2 Now Available Blog bot DAX Blogs 0 27.01.2015 05:11
dynamicscpm: What do I need to configure in Dynamics AX to get the most out of Management Reporter? Blog bot DAX Blogs 0 31.08.2013 01:18
dynamicscpm: Migrating to Management Reporter 2012 Blog bot DAX Blogs 0 24.05.2012 01:13
dynamicscpm: How can you get Management Reporter 2012? Blog bot DAX Blogs 0 11.04.2012 18:11
Часовой пояс GMT +3, время: 21:27.
