Старый 11.05.2016, 16:11   #1
emeadaxsupport: Key Clean up Features for InventSum and InventDim Tables
Источник: https://blogs.msdn.microsoft.com/axs...entdim-tables/
Author: Arnold van Wageningen Please find below a summary of the clean-up features we currently offer in regards to InventSum and InventDim tables which can be found under the menu: Inventory management > Periodic > Clean up. The Inventory Dimensions cleanup shows the following help text: “The ‘Clean up unused inventory dimensions’ batch process deletes... Read more
inventdim, inventsum, очистка, очистка таблиц
DynamicsAxSCM: Migration of Microsoft Dynamics AX WMS to new R3 warehouse and transportation functionality Blog bot DAX Blogs 0 17.08.2015 20:19
Dynamics AX Sustained Engineering: KB3030212 Duplicate InventDim records are created which cause errors in the WHS if license plate IDs include trailing blanks Blog bot DAX Blogs 0 22.01.2015 20:12
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
emeadaxsupport: How to implement basic authentication with Dynamics Ax 2012 web services Blog bot DAX Blogs 0 24.04.2013 08:12
emeadaxsupport: Performance Improvement on "Multisite activation – Dimension inconsistency clean-up" Job Blog bot DAX Blogs 0 26.11.2010 00:12
Часовой пояс GMT +3, время: 20:11.
