Старый 03.10.2016, 16:11   #1
sashanazarov: Bugs in the DateTimeUtil::getSystemDateTime()
Источник: http://sashanazarov.blogspot.com/201...mdatetime.html
After the current system date is changed, either from the user interface or via systemDateSet function, the DateTimeUtil::getSystemDateTime() goes out of control. Don't ever use this function for unique keys generation.
Unfortunately, they use it a lot in the DIXF.
static void printDateTimeJob(Args _args)
void printDateTime()
info(strFmt('systemDateGet: %1 %2',
systemDateGet(),
time2StrHMS(timeNow())));
info(strFmt('getSystemDateTime: %1', DateTimeUtil::getSystemDateTime()));
info(strFmt('utcNow: %1', DateTimeUtil::utcNow()));
warning('Before date/time change');
printDateTime();
sleep(2000);
info('...2 seconds later:');
printDateTime();
systemDateSet(systemDateGet() - 3);
warning('System date changed:');
printDateTime();
sleep(2000);
printDateTime();
systemDateSet(systemDateGet() + 3);
warning('System date is back:');
printDateTime();
sleep(2000);
printDateTime();
And this is the result:
P. S.: Kernel version 6.3.4000.1745, Application version 6.3.3000.110
dynamicscpm: Management Reporter bugs now available in LCS Issue Search Blog bot DAX Blogs 0 13.06.2015 00:14
NAV Team: Reusable Bugs Blog bot Dynamics CRM: Blogs 0 01.04.2015 11:00
gustafwesterlund: Bugs and suggestions Blog bot Dynamics CRM: Blogs 0 20.11.2013 17:11
ax-erp: Dynamics Ax 2009 using the DateTimeUtil Blog bot DAX Blogs 0 09.10.2012 17:11
saveenr: Pragmatic Bug Modeling or When will all the bugs be fixed? Blog bot DAX Blogs 0 19.12.2010 03:26
Часовой пояс GMT +3, время: 14:36.
