Старый 02.11.2016, 07:15   #1
emeadaxsupport: SSRS Report label shown as @SYSxxxx in AX2012
Источник: https://blogs.msdn.microsoft.com/axs...xxx-in-ax2012/
Here in this blog I will share two scenarios when this happening and basic troubleshooting steps when facing this issue. Issue: When you are rendering SSRS report, the data will load correctly, but all AX labels are not resolved: Two known causes of this: SQL Server Reporting service version does not meet AX requirement. You... Read more
ax2012, ssrs, метки
emeadaxsupport: SSRS report tips to adjust alignment for pre-formatted print stock (i.e. 1099-MISC form) Blog bot DAX Blogs 0 08.01.2015 18:11
ax-erp: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: SSRS error in AX2012 - An item with the same key has already been added Blog bot DAX Blogs 0 13.03.2012 18:11
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
Часовой пояс GMT +3, время: 00:39.
