Старый 16.02.2018, 11:11   #1
crmtipoftheday: Tip #1077: Connect to the right instance
Источник: https://crmtipoftheday.com/1077/conn...ight-instance/
As Guido “Future Olive Farmer” Preite has discovered, sometimes CrmServiceClient may connect to the wrong instance. Just like that.
Dynamics 365 instances now can be backed up and restored at will. The side-effect of this awesomeness is that URLs and unique names may no longer match, leading to the fun times with connections. Here’s the scenario:
If you do experience this behavior, the workaround is to specify organization unique name in the connection string, i.e. use https://org1234567.crm.dynamics.com as URL parameter.
Thanks to Clément “French but not Tanguy” Olivier for the workaround and Matt “SDK Deity” Barbour for explaining the scenario.
(Facebook/Twitter cover photo by John Carlisle on Unsplash)
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1058: Connect to version 9 in your code Blog bot Dynamics CRM: Blogs 0 22.01.2018 03:48
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
ошибка в AIF syl DAX: Программирование 14 20.08.2015 15:25
Часовой пояс GMT +3, время: 16:46.
