Старый 09.04.2009, 09:05   #1
Fred Shen: X++ code to remove identical copy
Источник: http://fredshen.spaces.live.com/Blog...E4E3!258.entry
Our client asked for a job to remove the identical copy from VAR layer.
For some unknown reason, some AOT objects are touched in VAR layer but actually are identical copy. When the developer compared the VAR layer object with the one in lower layer (BUS, SYS etc.), AX showed it was an identical copy.
Here is the example on how you can remove the identical copy in X++ code:
static void FindAndDeleteIdenticalObjects(Args _args)
    SysTreeNode     comparable1, comparable2;
    TreeNode          treeNode, curLevelTreeNode, upperLevelTreeNode;
    UtilIdElements    utilElements, joinUtilElements;
    str                     nodePath;
    while select UtilElements
        where UtilElements.utilLevel        == UtilEntryLevel::var &&
                UtilElements.recordType     == UtilElementType::Form         ||
                Utilelements.recordType     == UtilElementType::Report      ||
                Utilelements.recordType     == UtilElementType::Table        ||
                Utilelements.recordType     == UtilElementType::Class         ||
                Utilelements.recordType     == UtilElementType::Enum        ||
                Utilelements.recordType     == UtilElementType::ExtendedType
        //Should use join if for a normal table, but not applicable for UtilElements
        //Performance hit if use exists join
        select firstonly recid joinUtilElements
            where joinUtilElements.utilLevel     !=  UtilElements.utilLevel    &&
                  joinUtilElements.name            == UtilElements.name        &&
                  joinUtilElements.recordType   == UtilElements.recordType;
        if (joinUtilElements.RecId)
            switch (UtilElements.recordType)
                case UtilElementType::Class:
                    nodePath = "Classes";
                    break;
                case UtilElementType::Form:
                    nodePath = "Forms";
                    break;
                case UtilElementType::Table:
                    nodePath = "Data dictionary\\Tables";
                    break;
                case UtilElementType::Enum:
                    nodePath = "Data dictionary\\Base Enums";
                    break;
                case UtilElementType::ExtendedType:
                    nodePath = "Data dictionary\\Extended Data Types";
                    break;
                case UtilElementType::Report:
                    nodePath = "Reports";
                    break;
            nodePath                   = nodePath + "\\" + UtilElements.name;
            treeNode                   = TreeNode::findNode(nodePath);
            curLevelTreeNode      = treeNode.getNodeInLayer(UtilEntryLevel::var);
            upperLevelTreeNode  = SysTreeNode::getLayeredNode(treenode, 1);
            comparable1              = SysTreeNode::newTreeNode(curLevelTreeNode);
            comparable2              = SysTreeNode::newTreeNode(upperLevelTreeNode);
            if (SysCompare::silentCompare(comparable1, comparable2))
                info(strFmt("Element name: %1, Element type: %2", UtilElements.name, enum2str(UtilElements.recordType)));
                //Remove the node
                treeNode.AOTdelete();
За это сообщение автора поблагодарили: aidsua (1), Gustav (0), shogel (1).
x++
Fred Shen: Consuming a Web Service in Dynamics AX 4 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Undefined nodes in System Documentation after applying KR1 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Read and alter registry settings in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 10:11.
