Старый 26.03.2007, 18:20   #1
axcoder: Tabax 0.3 beta 3
Источник: http://axcoder.blogspot.com/2007/03/...03-beta-3.html
Starting a beta stage of the new Tabax version (download)
What's new since 0.2.x:
  • Works with Ax 4 (icons are in tabax.ax4 they should be copied to "C:\Program Files\Microsoft Dynamics AX\Client\Share\Include\tabax")
  • User interface can be localized (it is translated already to Russian and Spanish (the last by Manel Querol (Mkz) from http://www.TrucosAx.com))
  • windows management (enable "fit maчimized" in setup and your window maximization will be emulated with fitting)
  • tab width setup (maximal width, minial width and "Tabs have same size")
  • Plugin SDK (it's only first small step)
  • Ivan Kashperuk added the "Open table field" functionality to the "Edit current field" buttonAutosize: tabax don't let to change it's size
axcoder: Tabax is one year old Blog bot DAX Blogs 0 03.10.2007 17:10
axcoder: Tabax v 0.3 Blog bot DAX Blogs 0 14.05.2007 18:00
axcoder: Tabax 0.2.15 -- fit mazimized windows Blog bot DAX Blogs 0 10.03.2007 01:36
axcoder: Tabax 0.2.14: View query of the active datasource Blog bot DAX Blogs 2 02.02.2007 12:10
axcoder: Tabax 0.2.13 Blog bot DAX Blogs 0 26.01.2007 05:45
Часовой пояс GMT +3, время: 12:59.
