Kashperuk Ivan: Fetching Data experiment (CacheLookup property)
Источник: http://kashperuk.blogspot.com/2007/0...chelookup.html
============== Playing around with certain table properties at work, trying to improve performance, I decided to post some results today. The original job was taken from the Dynamics AX Development training materials (III and IV), which, taking the opportunity, I would like to recommend for reading. Especially I enjoyed chapters dealing with performance issues (a topic that is very interesting to me :)) Well, they write about measuring caching there, which they, actually, shouldn't do, because the job they provided won't work in DAX 4.0 (the counters will be zero) (I guess it was simply copy-pasted from DAX 3.0 training materials - you should never use copy-paste, especially with code :) - trust me, been there many times) Anyhow, I modified the job a little bit to make my research a little easier. Here are the results I have received for SalesTable: Basically, running the job may help you decide, what is the best CacheLookup property value for a given table. But first priority is reading about it in tutorials or the Inside Dynamics AX book (basically, it's almost the same information on this topic) You can do some R&D yourself by downloading the job: download Have fun! Also visit the homepage Источник: http://kashperuk.blogspot.com/2007/0...chelookup.html
