Старый 25.01.2008, 17:10   #1
Khue Trinh: Example of using a list
Источник: http://khue.spaces.live.com/Blog/cns...A0C2!396.entry
List can be used to store a list of elements and this type is quite portable for quick manipulation.
You can either use ListEnumerator or ListIterator. These 2 classes are quite similar unless must use ListIterator if you want to delete an element in the list.
static void STU_List(Args _args)
    List            lst;       //list
    ListEnumerator  lstEnum;   //traverse through the elements in the list
    CustTable       custTable;
    VendTable       vendTable;
    Common          common;
    int             i;
    lst            = new List(Types::Record);
    lstEnum    = lst.getEnumerator();
    lst.addEnd(CustTable::find("4000"));
    lst.addEnd(VendTable::find("3000"));
    lst.addStart(CustTable::find("4020"));
    info(lst.toString());
    info(lst.definitionString());
    info(lstEnum.toString());
    info(lstEnum.definitionString());
    lstEnum.reset();
    lstEnum.moveNext();        //must move next to get to the first
<font face="Courier New" size=2>    for(i=0; i
Khue Trinh: Alternative Item Blog bot DAX Blogs 0 09.04.2009 16:05
Khue Trinh: Set up & perform Global Search Blog bot DAX Blogs 0 26.01.2008 18:22
Khue Trinh: How to get Inventory On-hand number Blog bot DAX Blogs 17 11.01.2008 22:23
Khue Trinh: Mass Deployment of the Microsoft Dynamics AX Client Blog bot DAX Blogs 0 07.01.2008 15:51
Khue Trinh: Be careful with Inventory journal Blog bot DAX Blogs 0 07.01.2008 15:51
Часовой пояс GMT +3, время: 03:21.
