Старый 26.08.2008, 08:41   #1
susenyudha is offline
susenyudha
Аватар для susenyudha
1 / 10 (1) +
-> method insert() when insert table from outside
hi guys,
I have a problem when I insert record into table from outside of AX, can I do insert() method on axapta?
I want to check something on insert() method, can I ?
any solutions?
thanks
(sorry, my english is bad )
some thing big is won't be a big thing, if you don't know a little thing
Старый 29.08.2008, 18:51   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от susenyudha Посмотреть сообщение
I have a problem when I insert record into table from outside of AX, can I do insert() method on axapta? I want to check something on insert() method, can I ?
So you're using AX Business Connector to insert a new record in a table, right? You don't mention which version of Axapta you're using and what kind of Business Connector (COM or .NET), so let's take .NET Business Connector for instance. AFAIK when you call AxaptaRecord.Insert(), it internally calls the insert() method on the table. Hence you can add any checks to the insert() method in the application and these checks or whatever code you add will be automatically invoked when you insert a record using AX Business Connector.
And in case you mean you insert a new record via a direct SQL connection to an AX database the answer is: stop doing this immediately and use AX Business Connector instead.
X++: Using the Cross company feature from the Business Connector and table browser. Blog bot DAX Blogs 1 21.12.2008 01:17
TwC: Validate access to return value from display/edit method. алька DAX: Программирование 3 20.04.2007 14:15
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 14:59.
