Старый 22.01.2007, 23:50   #1
tomb: Change in the way hotfixes are handled going forward
Источник: http://blogs.msdn.com/tomb/archive/2...g-forward.aspx
The process for developing, building, and releasing application hot fixes and updates will fundamentally change from Microsoft Dynamics AX 4.0 SP1 onwards. The hot fix layer files will be made cumulative in the sense that previous fixes will be included in the latest released hot fix or the next critical update. Due to this cumulative approach, released hot fixes are expected to be tested in conjunction with all supported updates and their fixes. In this way, we intend to reduce conflicts between fixes. </SPAN>
Another major difference between the patching strategy of Microsoft Dynamics AX 3.0 and 4.0 SP1 onwards, will be the type of hot fix deliverable. We expect to release cumulative hot fixes as an AOD file, which will be distributed out of the DIS layer inside Microsoft Dynamics AX. This should make it simpler to distinguish Microsoft code from code developed by a partner, as well as making it possible to use the inbuilt upgrade tools to upgrade a partner’s customization layer(s) in a similar manner to installing a service pack in Microsoft Dynamics AX 3.0. A major advantage of this new approach is that it will now be easier for Microsoft as well as partners to better determine the current hot fix status of any customer system. </SPAN>
We expect that all cumulative hot fixes will be rolled forward into the next critical update and major release, so that partners upgrading their customers to a new major release should only need to delete the entire DIS layer to help ensure a smoother upgrade path.</SPAN>
Старый 17.02.2009, 14:14   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
New Application Patching Strategy for Microsoft Dynamics AX 4.0 SP1
partnersource
https://mbs.microsoft.com/partnersou...rintpage=false
Дата изменения 17.02.2009
Отправлено 16.02.2009
AX UK: Standard Rate of VAT Change - effective 1st Dec 2008 Blog bot DAX Blogs 0 25.11.2008 17:05
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
PatrickChua: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 18:14
Fred Shen: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 08:12.
