Старый 01.04.2009, 05:07   #1
Microsoft Dynamics CRM Team Blog: CRM 4.0: Checkbox style Multi-Select Picklist
Источник: http://blogs.msdn.com/crm/archive/20...-picklist.aspx
Our guest blogger is CRM MVP Jim Wang joining us from Reading England. Jim blogs regularly at Microsoft Dynamics CRM – Jim Wang’s technical blog [MVP].
CRM 4.0 doesn't have many out-of-box user controls, such as multi-select picklists. The standard CRM picklist can only save one value in the database, it's not easy to extend this functionality, in addition, you have to deal with the Advanced Find feature.
You can make a picklist multi-selectable by enable the picklist multiple attribute , e.g: crmForm.all.new_picklist.multiple = true; And then save the selected values somewhere else. However, it does not very impressive the user because the user has to use the CTRL key to select options, which is not user-friendly (Thanks for Alastair Westland (PM @ Parity) who work with me to improve the interface design:)
The script below will draw a checkbox style multi-select picklist control on the CRM form, and then get options from the real picklist attribute. So how to use it?
1. Create a standard picklist attribute with all options in CRM, put it on the CRM Form. e.g: new_picklist;
2. Create another nvarchar attribute in CRM to save the selected text, put it on the CRM Form and hide the label. e.g. new_picklistvalue;
3. Put the following script in the Form.OnLoad() event.
author: Jim Wang @ January 2009
[url]http://jianwang.blogspot.com[/url]
// PL - the picklist attribute; PLV - used to save selected picklist values
var PL = crmForm.all.new_picklist;
var PLV = crmForm.all.new_picklistvalue;
if( PL != null && PLV != null )
  PL.style.display = "none";
  PLV.style.display = "none";
  // Create a DIV container
  var addDiv = document.createElement("<div style='overflow-y:auto; height:80px; border:1px #6699cc solid; background-color:#ffffff;' />");
  PL.parentNode.appendChild(addDiv);
  // Initialise checkbox controls
  for( var i = 1; i < PL.options.length; i++ )
    var pOption = PL.options[i];
    if( !IsChecked( pOption.text ) )
      var addInput = document.createElement("<input type='checkbox' style='border:none; width:25px; align:left;' />" );
    else
      var addInput = document.createElement("<input type='checkbox' checked='checked' style='border:none; width:25px; align:left;' />" );
    var addLabel = document.createElement( "<label />");
    addLabel.innerText = pOption.text;
    var addBr = document.createElement( "
"); //it's a 'br' flag
    PL.nextSibling.appendChild(addInput);
    PL.nextSibling.appendChild(addLabel);
    PL.nextSibling.appendChild(addBr);
  // Check if it is selected
  function IsChecked( pText )
    if(PLV.value != "")
      var PLVT = PLV.value.split("||");
      for( var i = 0; i < PLVT.length; i++ )
        if( PLVT[i] == pText )
          return true;
    return false;
  // Save the selected text, this filed can also be used in Advanced Find
  crmForm.attachEvent( "onsave" , OnSave);
  function OnSave()
    PLV.value = "";
    var getInput = PL.nextSibling.getElementsByTagName("input");
    for( var i = 0; i < getInput.length; i++ )
      if( getInput[i].checked)
        PLV.value += getInput[i].nextSibling.innerText + "||";
Cheers,
Jim Wang
Последний раз редактировалось Aleksey_M; 02.04.2009 в 12:19. Причина: код с оригинала скопировал
Microsoft Dynamics CRM Team Blog: Highlight: Available downloads for Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 0 05.11.2008 22:05
Часовой пояс GMT +3, время: 15:09.
