Старый 28.06.2009, 03:06   #1
C# and AX Development: How to delete AOT nodes by code (UtilIdElements solution)
Источник: http://olondono.blogspot.com/2009/06...s-by-code.html
In my old post: How to delete AOT objects (AX/Axapta), I have used the TreeNode class. There is another useful method by using the UtilIdElements system table described in the following links:
- MS KB 913530 (CustomerSource)
- forum topic: microsoft.public.axapta.programming - Currupt records in UtilIdElement and UtilElements
Warning: Serious problems might occur if you modify the UtilIdElements table using this or another method. Modify system tables at your own risk.
The code:
static void Job1(Args _args) { UtilIdElements utilElement; ; ttsbegin; select utilElement where utilElement.name == 'myElementName' && utilElement.utilLevel == utilEntryLevel::cus // any layer && utilElement.recordType == utilElementType::Table; // object type if (utilelement) { utilElement.delete(); ttscommit; info('Record should be deleted now.'); } else { ttsAbort; info('Could not delete record, or it was not found.'); } }
Часовой пояс GMT +3, время: 22:05.
