Старый 15.09.2009, 13:22   #1
Kent is offline
Kent
ClassFactory.createViewer
How can I get "args" in ClassFactory createViewer method? I need to known which table and record call report.
Старый 15.09.2009, 13:52   #2
DSPIC is offline
DSPIC
Боец
1,077 / 1243 (44) ++++++++
This method is called from the run() method of the SysReportRun class (in the super() method).
\Classes\SysReportRun\run
Staying at SysReportRun you can always get an original reportRun instance or its calling parameters.
Good luck!
Старый 15.09.2009, 14:02   #3
Kent is offline
Kent
I need get caller in this method. By different callers I should call different ReportOutputUserType
ClassFactory Andrux DAX: Программирование 2 30.05.2008 12:22
dax-dilettante: 15. System Classes \ The Global Session Classes Blog bot DAX Blogs 0 26.09.2007 23:51
aEremenko: Доступность appl.globalCache() для всех сессий DAX Blog bot DAX Blogs 0 17.04.2007 18:01
добраться из ClassFactory "обратно" до класса somebody DAX: Программирование 18 11.08.2005 18:07
classFactory.lastValueGet DreamCreator DAX: Программирование 4 14.01.2005 12:18
Часовой пояс GMT +3, время: 13:48.
