Старый 15.09.2010, 17:05   #1
paruvella: Ax EP - AxBoundField - OnDataChange Event
Источник: http://paruvella.spaces.live.com/Blo...4DB0!552.entry
Here I want to achieve, if the AxBoundField have some value, need to enable/disable button accordingly.
I had struggled little bit, to raise the event OnDataChanged for AxBoundField control when data changed for this bound control.
Then, have used following markup code for Bound control.
</span>
While adding the bound fields to the AxForm, we won’t get this attribute AutoPostBack="true"to the AxBoundField.
To raise the OnDataChanged event,  explicitly need to add the above attribute to AxBoundField.
Then I had added the following code to the event …
protected void ProjId_OnDataChanged(object sender, AxBoundFieldDataChangedEventArgs e)
        string expProjId = ((System.Web.UI.WebControls.TextBox)(e.BoundControl)).Text.ToString();
                if (expProjId != "")
                    ButtonOK.Enabled = true;
                else
                    ButtonOK.Enabled = false;
paruvella: Displaying the Standard Ax report in EP pages of AX – Part – II Blog bot DAX Blogs 0 13.05.2010 01:05
paruvella: Displaying the Standard Ax report in EP pages of AX Blog bot DAX Blogs 0 04.05.2010 18:05
paruvella: Displaying SSRS report in Ax-EP page Blog bot DAX Blogs 0 02.02.2010 21:05
paruvella: Displaying the employee images on the EP pages of Dynamics Ax Blog bot DAX Blogs 0 15.12.2009 23:05
paruvella: Hints on Workflow implementation for EP in Ax 2009 Blog bot DAX Blogs 0 12.11.2009 21:05
Часовой пояс GMT +3, время: 10:10.
