Старый 18.09.2010, 21:06   #1
Dynamics Ax: Workflow Error “No .NET Business Connector Session could be found” in Dynamics AX2009
Источник: http://sangi1983.spaces.live.com/Blo...B1D3!603.entry
Have you ever encountered such type of error in Workflow? Well I did…
I tried to submit a Workflow Purchase requisition and I ended up getting the following error constantly in my event Viewer. However there was no error in the AX client when submitting the workflow.
I performed the basic trouble-shooting as below.
1)    Checked the Business Connector Proxy in the System Service Account.
2)    Checked the Business connector setting of the AX rich client.
Performing these steps didn’t work for me.
The actual issue was: “The logon password was changed for the local system”. Due to which there was a Host runtime error.
In order to fix the issue please perform the following steps.
·         Go Internet Information Service Manager
I.e. Start à Run à Type in inetmgr
·         Expand the Application Pools and select the configured Workflow
I.e. In my case it’s MicrosoftDynamicsAXWorkflow50
·         Go to MicrosoftDynamicsAXWorkflow50 properties.
·         Under Identity tab in the “Application pool identity please change the password to the local system password which was changed recently”.
·         Stop IIS
·         Start IIS.
Now try to resubmit the workflow and you’ll find that it has executed successfully.
ax2009, business connector, workflow
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 01:33.
