Старый 05.02.2011, 07:13   #1
daxdilip: Troubleshooting Dynamics AX 2009 EP Thread abort Exception Error
Источник: http://daxdilip.blogspot.com/2011/02...x-2009-ep.html
Issue:
We had this problem where all of a sudden some of the EP Users were not able to navigate through the EP pages.
Below is the snapshot of the error which comes up in the EP Page. Sharepoint as usual doesn't show informative/descriptive errors and it's quite difficult to debug sharepoint pages, so my next bet was to look into Event Viewer to get a more detailed description of the error.
Event Viewer Log:
Dynamics Object Adapter Call failed Thread was being aborted
System.Threading.ThreadAbortException
at AxCore_Call(UInt64 , Char* , tagVARIANT* , Int32 , tagVARIANT* )
at Microsoft.Dynamics.BusinessConnectorNet.AxaptaObject.Call(String methodName, Object[] paramList)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName)
Microsoft Dynamics AX Business Connector Session 444.
Thread was being aborted.
Session Release for Microsoft Dynamics failed.
No .NET Business Connector session could be found.
Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.NoKernelSessionException
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.get_AxaptaAdapter()
at Microsoft.Dynamics.Framework.Portal.AxWebSession.WebSessionClientRemove()
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.Release(ICacheContext context)
Resolution
Fristly, I googled to see if somebody else has experienced similar error, found this link
http://graycloud.com/axapta/enterpri...ct-t51380.html,
it's the same issue but there's no solution.
I tried IISreset from the EP server but that didn't help. Opened AX and deleted the user cache but still this didn't help, finally had to delete and recreate the user to solve the problem, We are on the latest service pack and rollup 6 for Dynamics AX 2009 so I'm not sure if this is a bug which would be addressed in the future.
Часовой пояс GMT +3, время: 06:04.
