Старый 07.02.2011, 01:14   #1
Harish Mohanbabu: Book on 'Microsoft Dynamics AX 2009 Administration'
Источник: http://harish-m.livejournal.com/31212.html
I have had the pleasure and privilege to work on my third book on Microsoft Dynamics AX as Technical Reviewer.
As the title indicates, 'Microsoft Dynamics AX 2009 Administration' is focused primarily on the set up and configuration aspects of DAX 2009. In particular this book covers following aspects -
  • Master the components required to set up and configure Dynamics AX 2009 in your business and effectively manage your business data.
  • Understand the current hardware, software, and network infrastructure in which you will be implementing Microsoft Dynamics AX.
  • Maximize the stability and performance of your Dynamics AX environment.
  • Fully understand the base Dynamics AX 2009 components and their features to get your Dynamics AX environment up and running effectively
  • Implement the Enterprise Portal, a web-based solution to access data from Dynamics AX and perform many functions such as Purchase Requisitions, Sales Orders, Customer lookups, and CRM
  • Understand how to set up and configure the business intelligence and advanced reporting capabilities of your data by using the Role Centers in Dynamics AX
  • Enhance the security of multiple services by ensuring that the Kerberos Authentication protocol is implemented in your Dynamics AX environment.
  • Learn the process of setting up and configuring workflow to fit the needs of a company that requires various workflow capabilities
  • Discover how to use the Application Integration Framework to exchange data either synchronously or asynchronously between one system and another
  • Manage, migrate, and convert your data in Dynamics AX
  • Get a hold of the common user administration functions that are built into Dynamics AX, including setting up domains and importing users, permissions, profiles and company accounts
  • Make critical, timely business decisions by fully understanding the Alerts and Notifications features that notify you when specific criteria have been met with your data
  • Tweak and enhance Dynamics AX and its components for optimal performance
  • Learn how to maintain the data integrity of Dynamics AX data and develop backup and recovery processes
Lots of efforts have gone into this book to ensure that this book meets the very high expectations from wider DAX community. This book is published by Packt Publications and I take this opportunity to thank the publication team for all their efforts.
ax2009, book, администрирование, книга
lcash: Inside Microsoft Dynamics AX 2009 Book Blog bot DAX Blogs 0 24.07.2009 04:20
chrisfie: Microsoft Dynamics AX 2009 and Microsoft Project Server 2007 Demo Image Blog bot DAX Blogs 2 03.07.2009 20:05
AX UK: Pre-Sales Demonstration Toolkit For Microsoft Dynamics AX 2009 - Refresh 1 - Available now Blog bot DAX Blogs 0 24.02.2009 18:05
Dynamics AX: Microsoft Dynamics AX 2009 SDK Blog bot DAX Blogs 0 13.06.2008 19:05
Часовой пояс GMT +3, время: 21:27.
