Старый 12.05.2011, 15:11   #1
sumitax: AX2012 Features – Financial Dimensions changes
Источник: http://sumitax.wordpress.com/2011/05...sions-changes/
I havebeen  reading changes in AX2012 w.r.t to last version and I found that Financial Dimension got a major change in AX2012. The financial dimension has undergone a major change. In AX2009, a ledger account was represented by a single string value and was considered to be separate from the financial dimensions.  All financial dimension values were stored in the Dimensions table.In Microsoft Dynamics AX 2012, a major change is that now you can use multiple number of dimensions which is different from AX2009 where we can create up to 10  financial dimension. Following are summary of changes  :
  1. The setting up of Financial dimension for AX records such as customer records is still the same but the recid will be stored in “DimensionAttributeValueSet” Table for reference.
  2. Dimension attribute set pattern which is used to store additional information about  dimension is still used used but now  foreign key represents a dimension attribute that contains data from corresponding Recid field  of “DimensionSetAttribute” table.
 I will write a separate post about code changes that need to considered while upgrading objects from previous version to AX2012.
sumitax: AX2012 Features -Getting earth friendly with new Dashboard Blog bot DAX Blogs 0 26.04.2011 20:11
sumitax: AX2012 Training material download Blog bot DAX Blogs 0 11.04.2011 13:11
sumitax: AX2012 – Interview with Kees Hertogh – Microsoft’s Dynamics AX Product Director Blog bot DAX Blogs 1 26.03.2011 10:47
sumitax: AX2012 – What’s in store in new version Blog bot DAX Blogs 0 31.01.2011 16:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 03:06.
