Старый 22.08.2012, 21:11   #1
workflowax: Organisation-wide Workflow Email Templates
Источник: http://workflowax.wordpress.com/2012...ail-templates/
If you make use of organisation wide workflow configurations in AX2012 you may have come across an issue where users are not notified of their new work-items via Email.
To set this up you will need to:
1. Navigate to your email templates under the Setup menu of “Organisation Administration”.
2. Select the “Show system email templates”
3. Create a new Email template.
4. Navigate to “System Administration” -> “Setup” -> “Workflow Parameters” and select your newly created email template. (For company specific configuration AX looks at the template selected under “Organisation Administration” -> Setup -> Workflow Parameters)
Your users should now be notified of “Organisation-wide” workflow workitems.
workflowax: Approve Workflow Items Via Email Blog bot DAX Blogs 0 07.05.2012 11:11
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Microsoft Dynamics CRM Team Blog: Adding attachments to Templates and Bulk email Blog bot Dynamics CRM: Blogs 1 29.12.2010 15:43
workflowax: What is a workflow owner used for? Blog bot DAX Blogs 0 01.06.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 11:26.
