Старый 07.09.2012, 07:11   #1
axblog4u: Tip: Suppress “Save Changes” prompt when you close a Excel workbook using X++ in Dynamics AX
Источник: http://axblog4u.wordpress.com/2012/0...n-dynamics-ax/
In Microsoft Dynamics AX, to read data from excel worksheets the focus needs to shift on the active workbook. So when application is closed you’ll still find the process thread being shown up in Task manager and when trying to view the excel file a dialog prompt appears
Prompt when you close workbook in Excel
To suppress the following, try forcing a workbook to close without saving changes. The best way of implementing this via x++ code [ sysExcelWorkbook.saved(true) ]
REASON:If Saved property is set to True, Excel responds as though the workbook has already been saved and no changes have occurred since that last save.
To know more on the way its handled in C#, refer MS link Workbook.Saved Property
axblog4u: Form Size Exceeds the Maximum Pixel in Dynamics AX Blog bot DAX Blogs 0 23.01.2011 10:12
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
dynamics-ax: Interview with Amber Kirkman, Director of Marketing - Sunrise Technologies Blog bot DAX Blogs 0 30.09.2010 23:06
Часовой пояс GMT +3, время: 18:42.
