Старый 15.10.2012, 12:11   #1
palleagermark: Saving the Financial Statement as PDF
Источник: http://palleagermark.blogspot.com/20...nt-as-pdf.html
This is just a small proof of concept on how you can save the Financial Statement as PDF without any further user interaction.
The example builds on the Excel export, but rather than showing the spreadsheet to the user, the spreadsheet is saved as PDF. When saved, the spreadsheet is closed without the user ever seeing it, and the PDF is opened in stead.
Download an XPO with the modifed class LedgerBalanceSheetDimPrintExcelEngine here.
Dynamics AX Sustained Engineering: Financial Statement calculation column behavior with Currency Converter Blog bot DAX Blogs 0 17.05.2011 01:14
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
palleagermark: Found a Sleep statement in AX 2009 released code Blog bot DAX Blogs 0 17.08.2009 14:05
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
daxmy: Financial Statement - Stack trace error Blog bot DAX Blogs 0 31.10.2007 17:40
Часовой пояс GMT +3, время: 21:23.
