Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 25.04.2014, 18:31   #1
Kent is offline
Kent
Ax 2012 Workflow Conditions to process next step
Hi,
In WF there is Conditional decision element, with True and False branches.
But it is not usable in cases, an example, when I need to check some field value and only move forward to next steps, if needed value is met. It could be done by True branche. But what to do with False branche? I don't need to do any actions in case of False. How to solve that kind of situation? Or should I use some other elements and other approach?
Thanks.
Старый 25.04.2014, 20:33   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
You could and should in that case pass link to the end of WF, cos if your condition return false (believe me, that may happens any time) system must do something. This is not X++, where you may stay unprocessed condition!
Axapta book for developer
emeadaxsupport: AX Content: Make Microsoft Dynamics AX 2012 yours! Blog bot DAX Blogs 0 01.10.2013 00:12
emeadaxsupport: Timesheet workflows in Project management and accounting AX 2012 Blog bot DAX Blogs 0 21.06.2013 15:11
palleagermark: Book review: Implementing Microsoft Dynamics AX 2012 with Sure Step Blog bot DAX Blogs 0 06.05.2013 11:11
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Часовой пояс GMT +3, время: 10:51.
