Старый 06.09.2014, 04:54   #1
atinkerersnotebook: Quickly Update Data Through X++ Scripts
Источник: http://atinkerersnotebook.com/2014/0...ugh-x-scripts/
Originally posted on Dynamics AX Tip Of The Day:
Normally I don’t promote to coding scripts within Dynamics AX because it is always perceived as something that a developer has to do. And for the power user, there are so many other ways to tinker with the system that getting your hands dirty with X++ is not necessary. One situation though that it’s sometimes just better to roll up your sleeves and write a little bit of X++ code is when it comes to updating masses of data. I’m not talking about updating 100 or so records because you can use Excel for that, but if you need to update 1,000’s or 10’s of thousands of records then Excel can be a little slow, and a script is so much faster.
Hopefully this worked example will demystify scripting a little and make you feel a little like a Whiz Kid.
View original 346 more words
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Часовой пояс GMT +3, время: 05:34.
