Any function that accepts only one parameter can be called as if it were a property, and this applies to built-in system functions, your own custom functions, and even .NET methods alike. Instead of doing it like Report50001.SetDefaultPostingDate(101015D) you can always do it like Report50001.SetDefaultPostingDate := 101015D. Of course you can improve semantics of your code significantly if you simply call the function PostingDate instead of SetDefaultPostingDate, then you can just write Report50001.PostingDate := 101015D;
Remember – this works for all function types, even .NET method calls. Read this post at its original location at http://vjeko.com/blog/improving-sema...ion-properties, or visit the original blog at http://vjeko.com. 5e33c5f6cb90c441bd1f23d5b9eeca34The post Improving semantics through function properties appeared first on Vjeko.com. Читать дальше
