Старый 27.01.2015, 05:11   #1
dynamicscpm: Management Reporter 2012 CU11 - Hotfix 2 Now Available
Источник: http://blogs.msdn.com/b/dynamics_fin...available.aspx
An optional hotfix rollup is now available for Management Reporter 2012 CU11. We are trying something new for this release, and will be releasing a hotfix every few weeks with the bugs we have completed fixing in that timeframe. You can take the hotfix release if there is a bug impacting you, or you can wait until there is a cumulative update available, just like previous releases. We think that this approach will help to get fixes in the hands of customers faster and will be beneficial to everyone.
This hotfix can be used as an upgrade from a previous release of Management Reporter, upgrade from CU11 Hotfix 1, or as a new full installation. The hotfix will require you to upgrade both the Management Reporter and the data mart database.
Bug ID
Title3278977 -Generator and Designer users do not have access to any companies3268668 -Customer Name transaction attribute not correct when using a virtual company with a shared table collection that includes CustTable3298557 -Maintenance task execution causing informational messages in SQL log3274360 -Foreign key constraint error when removing a user from Management Reporter with an AX integration3214544 -Data mart integration user is not provided with the ALTER permission when granted the view change tracking permission which causes an error when running update statistics3214713 -In the Web Viewer, there is no indication of currently active reporting tree node3213580 -BASE+1:12 does not work in a column definition3239105 -Initial Transaction to Fact error causes secondary SQL Datetime overflow error many times3249707 -You receive a System.ArguementOutOfRangeException that causes the Process Service to stop from a scheduled report
The EN-US version of this hotfix is posted to CustomerSource. The localized versions will be uploaded within the next few days.
Version History
Management Reporter CU11 RTM (removed) - 2.1.11000.32
Management Reporter CU11 Hotfix 1 and Re-Release - 2.1.11001.1
Management Reporter CU11 Hotfix 2 - 2.1.11002.5
dynamicscpm: Migrating to Management Reporter 2012 Blog bot DAX Blogs 0 24.05.2012 01:13
dynamicscpm: How can you get Management Reporter 2012? Blog bot DAX Blogs 0 11.04.2012 18:11
dynamicscpm: Management Reporter 2012 Released! Blog bot DAX Blogs 0 31.03.2012 23:11
dynamicscpm: We're reading and responding to your Management Reporter suggestions -- Management Reporter 2012 Feature Highlight Blog bot DAX Blogs 0 12.03.2012 23:11
Часовой пояс GMT +3, время: 23:15.
